Старый 07.01.2011, 11:56   #1
Lignik
Аватар для Lignik
По умолчанию Хочу заменить усь Rainbow iPaul DM2000
Хочу заменить Rainbow iPaul DM2000. Есть вариант VELAS VC-1108D что вы скажете и такой еще вопрос немогу найти инструкцию на Rainbow iPaul DM2000 можно ли его подключить в мостовом режиме чтоб поднять мощность?
Lignik вне форума   Ответить с цитированием Вверх
Старый 07.01.2011, 12:03   #2
tonni
Аватар для tonni
Rainbow: iPaul DM2000 - 1 channel Amplifier
SPECIFICATION:
Peak Power Output: 2000 Watts into one channel
1 x 1000 Watt RMS @ 1 Ohm or,
1 x 730 Watt RMS @ 2 Ohm or,
1 x 360 Watt RMS @4 Ohm
Frequency Response -3dB: 10 Hz - 250 Hz
24 dB Low-Pass: 50 Hz - 250 Hz
24 dB Subsonic Filter: 15 Hz - 50 Hz
Bass Boost: 45Hz, up to +12dB switchable
Phase Shifter 0° to 180°
Gain and Phase control via Remote control with 5m cable (included)
Total Harmonic Distortion: < 0.04 % @ 1W / 4 Ohm
Damping Factor: > 160 at 4Ohms
Operating voltage: 11V - 16V
Max input power/Peak current admission: 90A/155A
Efficiency: 85% with 14.4 DVC
Short circuit protection/Overloading: Immediate switch off
Connector for external fan module (optional)
Connector for temperature-sense and display module (optional)
Connector for peak power doubling module (optional)
Dimensions: WxHxD: 415mm x 60mm x 250mm
Weight: 5.5kg
Integrated falt fuses 2 x 25A
4-gauge power & earth input
MAIN FEATURES
Digital output amplifier (CLASS D) with integrated high-current MOSFET-switch power supply
Double output terminal for dual voice subwoofer, 1Ohm stable
Preamplifier with very low noise
Additional preamplifier output with LINEOUT
Reversible safety switch-off with thermal monitoring
Safety switch-off with DC current to loudspeakers
Safety switch-off for loudspeaker short-circuit and loudspeaker under impedance
Softstart remote muting for suppression of switch-on peaks
Low power requirements for remote-muting electrical circuits
High-tech semi-SMD built structure with low coupling conductive wiring
Palladium-plated 25 mmІ power and 10 mmІ loudspeaker connection
Interference-proof certified by European E-Norm
Старый 07.01.2011, 12:29   #3
Lignik
Аватар для Lignik
Спб.! но это я смотрел это Характеристики, а у меня нет инструкции, тут есть подключение мостом двух усилителей, но я ненаю можно ли подключить саб мостом, на уси у меня есть два входа как на двух канальном уси [+ -] [+ -] подключено у меня щас
[+ -], а я подумываю [+] [-] вот так.
Старый 07.01.2011, 19:45   #4
Это моноблок и канал там один.А две пары колодок для удобства-или пару дохлых сабов прицепить,или двухкатушечний.Ну с учетом сопротивления конечно.У многих моделей так.
Старый 07.01.2011, 19:53   #5
Вячеслав Меркулов
Аватар для Вячеслав Меркулов
Вы сказали Спасибо: 40
Сообщение от Lignik Посмотреть сообщение
Хочу заменить Rainbow iPaul DM2000. Есть вариант VELAS VC-1108D что вы скажете ...
Не слышал ни тот, ни другой...
Но что-то мне подсказывает, что не стоит...
Старый 07.01.2011, 22:23   #6
wollik
Аватар для wollik
Velas - дешевый хлам! лучше не стоит
Старый 08.01.2011, 03:05   #7
GZ-JBL Team
Аватар для GZ-JBL Team
Вы сказали Спасибо: 51
Post
если под давление то велас переплюнит данный рейнбоу как мальца.....
Страдивари с такого веласа при норм. питании снимали 1,7 кВт ..... и вроди бы на замер в 0,5 Ома пускали........
вот только где ты этот велик найдёш....????
Сч---может ли заменить Вч ???? ganss Белый шум 8 30.06.2011 17:31
на что заменить DLS? ttl Бюджетный автозвук и песочница. 23 02.06.2011 19:17
(1 канальный) Продам Rainbow: iPaul DM2000 Lignik Усилители 0 31.01.2011 22:55
Где ремонтироваться? Или чем заменить. Пасечник Практика по SQ 2 03.07.2007 09:32
Текущее время: 05:52. Часовой пояс GMT +2.
