Старый 24.11.2019, 21:54   #1
Александр М
Аватар для Александр М
По умолчанию Morel Limited Edition Carbon
Продається полный кит юбилейного топового мореля (розница 38000грн)
Ценник 10000...
0983248556 Киев Александр
Woofer
ELATE SW 6LE
Nominal Impedance
4 Ohm
Power Handling
200W
Max. Transient Power Handling
1000W
Sensitivity (2.83V/1M)
88dB
Frequency Response
25-4000Hz
FS
50Hz
Voice Coil Diameter
75mm (3.00")
Voice Coil Height
16mm (0.62")
Voice Coil Type/Former
Aluminum
Voice Coil Wire
Hexatech Aluminum
DC Resistance
4.10 Ohm
Voice Coil Inductance @1kHz
0.44MH
Magnet System
Hybrid rear vented
HE-Magnetic Gap Height
6mm (0.25")
B-Flux Density
0.8T
BL Product/BXL
7.07
Max. Linear Excursion/Xmax
10mm (±5mm)
Suspension Compliance CMS
0.560
Mechanical Q Factor QES
0.44
Total Q Factor Q/T
0.37
QMS
2.21
Mechanical Resistance RMS
2.44kgS¹
Moving Mass MMS
16.5gr (0.58oz)
Equivalent Car Air Load VAS
11L (0.39ft³)
Effective Pison Area SD
119cm² (18.45in²)
Cone Type
One-piece formed
Cone Material
Carbon Rohacell Sandwich
Unit Diameter
165mm (6.50")
Mounting Depth
61mm (2.40")
Mounting Cutout
141mm (5.55")
Net Weight
1.18kg (2.60lb)
TWEETER
MT-24LE
Nominal Impedance
6 Ohm
Power Handling
130W
350W
90dB
Frequency Response
1400-25000Hz
FS
700Hz
Voice Coil Diameter
28mm (1.10”)
Voice Coil Former
Aluminum
Voice Coil Wire
Hexatech Aluminum
DC Resistance
5.2 Ohm
Magnet System
Double magnet neodymium – H type
Dome Type
Acuflex Soft Dome
Dome Material
Silk
Unit Diameter
45mm (1.8")
Crossover
Accuset MX-22.2LE
Nominal Impedance
4 Ohm
Power Handling
280W
Crossover Point
1800Hz
Crossover Controls
Frequency slope cut: 6/12dB
Tweeter level: ±4dB (2dB steps)
Wiring Options
Standard, bi-amp, bi-wire
https://www.yumpu.com/en/document/re...er-guide-morel
https://www.google.com/url?sa=i&rct=...4711282321732м
Последний раз редактировалось Александр М; 24.11.2019 в 22:03.
Александр М вне форума   Ответить с цитированием Вверх
Старый 02.03.2020, 08:48   #2
papasan
Аватар для papasan
По умолчанию Re: Morel Limited Edition Carbon
В Одессе на неделе будете ?
papasan вне форума   Ответить с цитированием Вверх
(2 канальный) E.O.S. AE-35T Limited Edition Дмитрий Шатайло Усилители 5 27.07.2017 20:45
(4 канальный) E.O.S. AE-90F Limited Edition yupiter3 Усилители 1 29.06.2014 14:18
(2 канальный) E.O.S. AE-35T (Limited Edition ver. 2) Bezumniy Усилители 3 11.09.2011 12:01
(4 канальный) E.O.S. AE-90F Limited Edition s.e.r.i.k Усилители 9 04.05.2011 08:44
Morel Elate 6.3 Limited Edition KSANDR Практические уроки, технологии и материалы 7 17.08.2008 06:09
Текущее время: 17:17. Часовой пояс GMT +2.
