Старый 18.02.2013, 17:52   #6
antiradar
Аватар для antiradar
По умолчанию Re: Carpower Blackbass-10 в ящике
Цитата BLACKBASS - this does not merely describe the appearance of these new top-class subwoofers from CARPOWER. They provide a powerful and at the same time a very clear bass reproduction of low fundamental resonance up to the threshold of pain. In this price class, both the mechanical stability and the sound set standards.
High-power subwoofer, 2 x 250WMAX, 2 x 4Ω
The 25cm version of this bass speaker with carbon fibre cone also provides a powerful reproduction. High power capability, long excursion, perfect stability, and high quality materials applied at this speaker like special rubber surround and the extended CARPOWER full air circuit cooling of the drive system with rear ventilated spider, drilled pole core AND air gap provide an amazingly clear sound at every application. This 2 x 4Ω bass speaker with dual voice coil provides a bass reproduction of low fundamental resonance in bass-reflex cabinets of about 45 litres, real enjoyment also possible with closed cabinets, approx. 25 litres only.
Impedance (Z) 2 x 4Ω
Resonant frequency (fs) 32Hz
Max. frequency range f3-300Hz
Music power 2 x 250WMAX
Power rating (P) 2 x 175WRMS
SPL (1W/1m) 86dB
Suspension compl. (Cms) 0.19mm/N
Moving mass (Mms) 130g
Mech. Q factor (Qms) 7.2
Electr. Q factor (Qes) 0.46
Total Q factor (Qts) 0.43
Equivalent volume (Vas) 30 l
DC resistance (Re) 2 x 3.6/1 x 1.8Ω
Force factor (BxL) 10.5Tm
Voice coil induct. (Le) 2 x 0.7mH
Voice coil diameter 50mm
Voice coil former aluminium
Linear excursion (XMAX) ±15mm
Eff. cone area (Sd) 325cm2
Magnet weight 90oz.
Weight 5kg
Взято отсюда http://www.europe-audio.com/Product.asp?Product_ID=5622
Последний раз редактировалось antiradar; 18.02.2013 в 19:09.
(8") Воston G1 в ящике 35л Валодька Сабвуферы 2 04.06.2013 23:55
(10") Carpower BLACKBASS-10 -=red_line=- Сабвуферы 5 06.12.2012 14:54
(12") 2 дина Htrz es-300 в 1 закрытом ящике krvhr Сабвуферы 2 29.01.2012 20:04
(НЧ) Predator 6/8, BlackBass 12", MSH-100CHQ, SPH-130, Cross doctic Акустика 1 11.07.2011 18:46
(12") MTX T5512-04 в ящике ФИ sonor Сабвуферы 7 06.08.2010 08:45
Текущее время: 09:05. Часовой пояс GMT +2.
