| Акустика Объявления о продаже акустики |
Продається полный кит юбилейного топового мореля (розница 38000грн) Ценник 10000... 0983248556 Киев Александр Woofer ELATE SW 6LE Nominal Impedance 4 Ohm Power Handling 200W Max. Transient Power Handling 1000W Sensitivity (2.83V/1M) 88dB Frequency Response 25-4000Hz FS 50Hz Voice Coil Diameter 75mm (3.00") Voice Coil Height 16mm (0.62") Voice Coil Type/Former Aluminum Voice Coil Wire Hexatech Aluminum DC Resistance 4.10 Ohm Voice Coil Inductance @1kHz 0.44MH Magnet System Hybrid rear vented HE-Magnetic Gap Height 6mm (0.25") B-Flux Density 0.8T BL Product/BXL 7.07 Max. Linear Excursion/Xmax 10mm (±5mm) Suspension Compliance CMS 0.560 Mechanical Q Factor QES 0.44 Total Q Factor Q/T 0.37 QMS 2.21 Mechanical Resistance RMS 2.44kgS¹ Moving Mass MMS 16.5gr (0.58oz) Equivalent Car Air Load VAS 11L (0.39ft³) Effective Pison Area SD 119cm² (18.45in²) Cone Type One-piece formed Cone Material Carbon Rohacell Sandwich Unit Diameter 165mm (6.50") Mounting Depth 61mm (2.40") Mounting Cutout 141mm (5.55") Net Weight 1.18kg (2.60lb) TWEETER MT-24LE Nominal Impedance 6 Ohm Power Handling 130W Max. Transient Power Handling 350W Sensitivity (2.83V/1M) 90dB Frequency Response 1400-25000Hz FS 700Hz Voice Coil Diameter 28mm (1.10”) Voice Coil Former Aluminum Voice Coil Wire Hexatech Aluminum DC Resistance 5.2 Ohm Magnet System Double magnet neodymium – H type Dome Type Acuflex Soft Dome Dome Material Silk Unit Diameter 45mm (1.8") Crossover Accuset MX-22.2LE Nominal Impedance 4 Ohm Power Handling 280W Crossover Point 1800Hz Crossover Controls Frequency slope cut: 6/12dB Tweeter level: ±4dB (2dB steps) Wiring Options Standard, bi-amp, bi-wire https://www.yumpu.com/en/document/re...er-guide-morel https://www.google.com/url?sa=i&rct=...4711282321732м Последний раз редактировалось Александр М; 24.11.2019 в 21:03. |
| (2 канальный) E.O.S. AE-35T Limited Edition | Дмитрий Шатайло | Усилители | 5 | 27.07.2017 19:45 |
| (4 канальный) E.O.S. AE-90F Limited Edition | yupiter3 | Усилители | 1 | 29.06.2014 13:18 |
| (2 канальный) E.O.S. AE-35T (Limited Edition ver. 2) | Bezumniy | Усилители | 3 | 11.09.2011 11:01 |
| (4 канальный) E.O.S. AE-90F Limited Edition | s.e.r.i.k | Усилители | 9 | 04.05.2011 07:44 |
| Morel Elate 6.3 Limited Edition | KSANDR | Практические уроки, технологии и материалы | 7 | 17.08.2008 05:09 |
