#41 |
Вы сказали Спасибо: 61
![]() А я слушал пару инсталлов с ним...небуржуйских правда, один из низ у приятеля много раз слушал, в разных ящиках... и ни чем SWX меня не впечатлил... разве что глубиной. ИМХО за эти деньги есть варианты и по интереснее. Последний раз редактировалось m.a.k.c.; 14.02.2013 в 19:31. |
#42 | ||
Круг немного сузился, но малость сдвинулся.
На повестке дня следующие штуки:
- Morel Ultimo SC124Consistent with Morels philosophy, the Ultimo SC was designed to deliver innovative engineering resulting in extraordinary combination of audiophile bass quality and high power output at a great consumer value. The Ultimo SC employs some of the best technological features of the Ultimo subwoofer such as a gigantic 5.1” Hexatech™ External Voice coil (EVC™), a hexagonal-shaped aluminum coil wire (2-3 times thicker than standard subwoofers) that is used for accurate music reproduction and for superior durability and power handling. A highly efficient magnet system – DMM™ Double Magnet ferrite Motor that maximizes the magnetic field (over 90% efficiency).
The Ultimo SC subwoofer employs a unique hybrid paper-carbon fibre composite cone to achieve the extraordinary musicality in SQ application. Its chassis is composed of stamped steel and its power handling is 600WRMS. - rainbow PROFIPROFI
Vented double spider to prevent compression Extremely flexible surface-refined lead wires fixed via glue-points to guarantee resonance- and break-free operation Vented double magnet system for better magnet motor cooling and vented dust cap to prevent thermal compression Symmetrical pole piece for optimized magnet field symmetry Short cut ring made of copper to reduce distortions Optimized ferror-ceramics double magnet for high sensitivity with additional cooling via 8 mm chromium-plated backplate Suitable for enclosures of between 14 and 48 liters Application : bandpass, ported and sealed ![]() - rainbow VANADIUMVANADIUM
Aluminum die-cast basket for resonance-free operation Palladium-plated push terminals for high quality cables with large diameters Butyl rubber surround for controlled cone motion and minimal distortion Aluminum compound cone on polymer cellulose base offers authentic sound reproduction Concave dust cap form for optimal frequency response High-temperature, 40 – 75 mm voice coil former of black kapton for minimal current loss and maximum excursion Duroplastic-backed, low-inductivity, and vented voice coil with temperature-resistant glue Vented double spider to prevent compression Extremely flexible surface-refined lead wires fixed via glue-points to guarantee resonance- and break-free operation Vented double magnet system for better magnet motor cooling and vented dust cap to prevent thermal compression Symmetrical pole piece for optimized magnet field symmetry Short cut ring made of copper to reduce distortions Optimized ferror-ceramics double magnet for high sensitivity with additional cooling via 8 mm chromium-plated backplate Suitable for enclosures of between 16 and 33 liters Application : bandpass, ported and sealed ![]() Играть будет от твикнутого(direct) DLS A6. Фильтровать будет только проц. Очень нуждаюсь в конструктивных отзывах и советах!
#43 |
rainbow VANADIUM
тут кто то по халяве его сливал )))) или морель - лучше конечно с литой корзиной ))) СВ - он и по мощнее будет )) ![]() http://autozvuk.org/forum2/showthrea...inbow+VANADIUM ооооо |
#44 |
![]() а насчёт того, что в барахолке,- так там есть и Морел и Рэинбоу, да ещё и в одну цену.. |
#46 |
СВ как раз и есть то что нужно для сы ку. Катушка крупнее и перегрузить сложнее. Сделав правильный БОКС под него можно получить саб способный играть все ЖАНРЫ !!!!! Добавлено через 1 минуту Последний раз редактировалось Lukasarts; 17.02.2013 в 16:42. Причина: Добавлено сообщение |
#47 |
1) Скорость саба несовместима ни с длинным ходом подвижки ни с большой массой подвижной системы. 2) твикать сабовый усь, да ещё и под такие динамики - не имеет смысла. Толку, как от гравировки на артиллерийском орудии. |
#48 |
2) не имеет смыла т.к. динамики слишком недостойные, и на них не будет слышно разницы между твикнутым и стоковым моноблоком? а на каких будет слышно? Или моноблок слишком отстойный, чтобы его дорабатывать? |
#49 |
2) сабовый диапазон частот обычно не требует доработок. В этом диапазоне намного важнее блок питания усилителя, чем всё остальное. Поэтому шансы услышать изменения невелики, в этом будет больше самообмана, чем реального изменения. Обратите внимание на мою подпись. Сабовый усилитель я не трогал, а он у меня в системе уже около пяти лет. |
#50 |
2) а как-же расширить/усилить дорожки, заменить ОУ, и убрать фильтры вообще, освежить кондёры? или это не требуется? 3) что скажете о тех сабах, которые есть в этой теме? Добавлено через 11 минут Или брать оба? ![]() Кстати, насчёт того, что СВ под СПЛ, вроде-бы в описании этого саба на сайте производителя было.. "В Ultimo используются уникальный гибридный бумажно-карбоновый композитный диффузор, который является комбинацией музыкальности и громкости, что делает пригодным использование сабвуферов не только в аудиосистеме высокого уровня, но и в соревнованиях по максимальному звуковому давлению." А ещё, где-то на просторах инета встречалось упоминание о том, что у Morel Ultimo какое-то очень специфичное звучание, дескать, не на любое ухо.. Правда не уточнялось, что именно специфичного.. Последний раз редактировалось arvarc; 18.02.2013 в 16:56. Причина: Добавлено сообщение |
#53 |
![]() 2) При тяжелом, даже среднем сабе разница при замене ОУ - на уровне "показалось". Освежить кондёры - на хорошие кондёры нужно очень много денег, а менять на дешевые, можно сделать хуже. Опять таки сабовый усилитель должен успевать реагировать блоком питания, от конденсаторов внутри усилителя зависит немногое. Усилить дорожки - А6 не совсем бюджетный усь, на 4 Омном сабе разницы от этого усиления быть не должно. 3) Пирлесс, из того что в списке, самое приличное. |
#55 |
![]() Второе - здесь всё правильно крутил/вертел настройки кросов проца/усилка на суббасе разницы нет. Лучше потрать отложенные на твик усилка ассигнации, на хорошее питание моноблока... это будет рациональней. Вообще, коль есть средства на приобретение, то советую попробовать такую интересную вещь как "послушать" а не "почитать"... так проще найти ответы на поставленные вопросы в начале темы. Тебе уже повезло, ты в Киеве живешь. При всех вводных искать истину здесь - пижонство... может я утрирую, но все же... ![]() Личка не работает у тя потому кидаю в спойлер: Скрытый текстhttp://autozvuk.org/forum2/showthread.php?t=22051 http://autozvuk.org/forum2/showthread.php?t=21362 http://autozvuk.org/forum2/showthread.php?t=21715 http://autozvuk.org/forum2/showthread.php?t=19188 http://autozvuk.org/forum2/showthread.php?t=20948 http://autozvuk.org/forum2/showthread.php?t=21153 http://autozvuk.org/forum2/showthread.php?t=18913 http://autozvuk.org/forum2/showthread.php?t=20436 http://autozvuk.org/forum2/showthread.php?t=20875 Последний раз редактировалось m.a.k.c.; 18.02.2013 в 20:04. |
#57 |
Вы сказали Спасибо: 91
Ну,если все таки
"К тому-же я не слушаю тупое долбилово, и в драме и в дабстепе присутствует инструменталка, местами даже классическая.." ... то может Audio SystemHX-12SQ Самый музыкальный Сабвуфер 12 с бумажным диффузором или - если хочешь звездной пыли поглотать - Gladen Audio SQX12. Мировой рекорд Class Climber, Европейский чемпион Bassrace, Вице чемпион мира Bassrace... Все таки новое - и не так и дорАгА.. |
#58 |
Прежде чем лезть с паяльником в сабовый усь, дайте ему шанс - обеспечьте его нормальным питанием 50 кв.мм. (и это только на саб, а не на всю систему)
#59 |
Pioneer TS-W12PRS c DLS А6 и без твика, с нормальным питанием (в подписи на все уси по 35 мм кв, две AGM по 70А/ч) вполне удачная всеядная связочка (и скорость и глубина и т.д.), думаю вернусь опять к ней.
ps 1. Слушать, 2. Покупать. |
| (12") САбвуфер DLS MW 112 | koss04 | Сабвуферы | 12 | 25.02.2013 14:00 |
| (10") Сабвуфер DLS OA 10 D | Александр093 | Сабвуферы | 7 | 30.05.2011 08:02 |
| Усилитель,сабвуфер. | dok | Аксессуары, кроссоверы и прочее... | 9 | 12.03.2010 12:07 |
| Сабвуфер | Bacs | Куплю | 0 | 20.01.2010 09:23 |
