| dB Drag Racing Все о соревнованиях по версиям dB Drag Racing |
ПС: по этому поводу вопрос, не будет ли в Украине объединения Стоковых классов? ![]() С одной стороны хочется "потягаться", с другой чтоб с чашкой домой уехать... ![]() Добавлено через 1 минуту Ребята не путайте. Указано где нельзя делать изменения "норальная эксплуатация". В стоке должно быть все в заводских обшивках. Последний раз редактировалось antiradar; 22.01.2014 в 09:47. Причина: Добавлено сообщение |
Вы сказали Спасибо: 51
Gavronskiy, Серёга смотри внимательней!
![]() Нормальная эксплуатация везде! A Special Note on Normal Use: Most of the classes in dB Drag Racing require the vehicle to meet certain "Normal Use" requirements. (Please refer to the Class Matrix for the Normal Use requirements for each class.) Whenever a Normal Use restriction is specified, the sound system installation may not interfere with the normal operation of the vehicle as intended by the vehicle manufacturer. Examples: A subwoofer enclosure sitting on top of the rear seat in the Street Stock Division would prevent the seat from being used in the manner for which it was designed. Since the Street Stock Division requires Normal Use compliance "Everywhere", the installation would violate the Normal Use requirement. The rear-view mirror in the vehicle is missing. Since the sound system installation has nothing to do with the rear-view mirror, the Normal Use restriction does not apply. The air conditioner fan-blower motor was removed from the vehicle. If the removal of the motor was done to accommodate the sound system installation, then the Normal Use restriction is in violation. Otherwise, the removal is acceptable. A subwoofer enclosure is mounted in the cargo area of a hatchback. This does not violate the Normal Use requirement because the cargo area is intended as a general purpose area that can be used for applications such as this. The vehicle's seat belts are missing. If the removal of the seat belts was done to accommodate the installation of the sound system then the Normal Use requirement is in violation. Otherwise, the removal is ok. |
Вот это новость
Тогда подскажите, в стрит стоке всьо железо должно быть в багажнике или можно до средней стойке, и сколько до потолка, не могу понять?
Последний раз редактировалось Misha Design; 22.01.2014 в 12:04. |
Терапефт с пилюлями
Сегодня оглашен анонс изменений в BassRace:
результат будет фиксироваться с точностью до сотой после запятой, например, макс рез категории 129,9 будет 129,99. Благодаря этому будет меньше перезамеров в спаррингах при равных результатах, плюс могут достоверно определятья места с 3-го по 8-е при большой плотности резов. Технические детали, в т.ч. прошивка Термлаба, еще в работе. http://www.termpro.com/asp/pubs.asp?ID=317 |
| Календарь 2014 | GZ-JBL Team | dB Drag Racing | 80 | 12.01.2015 19:28 |
| ЕММА-Украина. Календарь 2014 г. | Директор Луны | EMMA | 35 | 04.08.2014 18:09 |
| СОЧИ-2014 | Директор Луны | Белый шум | 2 | 10.02.2014 21:34 |
| Членство dBDRA на 2014 сезон!!! | GZ-JBL Team | dB Drag Racing | 6 | 01.02.2014 22:33 |
